Good bye 24 consoles and chairsides
I can't fault you for getting rid of the Zeniths, and the low end consoles, but why get rid of the Stromberg Carlson "Skyscraper", the Motorolla, and the RCA 816K? Duplicates? That G.E console looks like a nice one as well, not really as flashy compared to many other late 30s sets but likely a good performer. By the way, what is that set with the slide rule dial and the Zenith Zepher style speaker grille second from the end in the first picture?
Good bye 24 consoles and chairsides - by y2kbruce - 04-24-2012, 06:22 PM
RE: Good bye 24 consoles and chairsides - by murf - 04-24-2012, 07:00 PM
RE: Good bye 24 consoles and chairsides - by Arran - 04-25-2012, 11:13 PM
There are currently 10442 online users. [Complete List]
» 2 Member(s) | 10440 Guest(s)
