37-660 Alignment Issue
Hello, Marv: The best way to align is to connect a volt meter to the voice coil leads of your speaker and use min sig gen amplitude when adjusting your set.
This prevents your AVC circuit from interfering with your alignment.
37-660 Alignment Issue - by marv - 04-26-2012, 08:10 PM
RE: 37-660 Alignment Issue - by TA Forbes - 04-26-2012, 09:09 PM
RE: 37-660 Alignment Issue - by LASJayhawk - 04-27-2012, 01:04 AM
RE: 37-660 Alignment Issue - by marv - 05-09-2012, 03:37 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7469 online users. [Complete List]
» 3 Member(s) | 7466 Guest(s)
