Opinions on pricing for Clarion AC-51
(04-26-2012, 09:11 PM)TA Forbes Wrote:  Hello, Murf: did you ever get it working?
Nope,
Sold it to a guy for $45.
Did not want to spend alot of time on it.
Opinions on pricing for Clarion AC-51 - by morzh - 04-26-2012, 10:50 AM
RE: Opinions on pricing for Clarion AC-51 - by murf - 04-26-2012, 09:42 PM
There are currently 10592 online users. [Complete List]
» 3 Member(s) | 10589 Guest(s)
