  • 1 Vote(s) - 5 Average
New Project16B Cathedral
(04-27-2012, 04:13 AM)glennpr Wrote:
(04-26-2012, 07:09 PM)TA Forbes Wrote:  Yes, thanks, Chuck, I forgot to mention the Philcorepairbench.com site as well. Between it and this site you will find the answers to your questions.
Also (I have zero connections to Chuck's site) I strongly recommend his schematic/info service. For a minimal amount you get quality, high resolution copies of all pertinent Philco info for your set. Many of the online schematics out there are tough to read and do not pertain to your specific code set.
Icon_thumbup +1 on Chuck's Info..
Glenn
Thanks for the votes of confidence. I just looked and I've been running The PRB since 1997 - back when the internet was fresh!
Geeze, time flies.....
Chuck
New Project16B Cathedral - by LedHed - 04-26-2012, 09:53 AM
RE: New Project16B Cathedral - by TA Forbes - 04-26-2012, 12:53 PM
RE: New Project16B Cathedral - by Chuck Schwark - 04-26-2012, 01:34 PM
RE: New Project16B Cathedral - by LedHed - 04-26-2012, 03:09 PM
RE: New Project16B Cathedral - by codefox1 - 04-26-2012, 04:18 PM
RE: New Project16B Cathedral - by TA Forbes - 04-26-2012, 07:09 PM
RE: New Project16B Cathedral - by Glenn Roberts - 04-27-2012, 04:13 AM
RE: New Project16B Cathedral - by Chuck Schwark - 04-27-2012, 10:03 AM
RE: New Project16B Cathedral - by Art Hoch - 05-31-2012, 08:47 PM
RE: New Project16B Cathedral - by TA Forbes - 05-31-2012, 11:41 PM
RE: New Project16B Cathedral - by jerryhawthorne - 06-03-2012, 10:44 PM
RE: New Project16B Cathedral - by codefox1 - 06-04-2012, 01:44 PM
RE: New Project16B Cathedral - by gary rabbitt - 06-05-2012, 12:38 AM
RE: New Project16B Cathedral - by jerryhawthorne - 06-21-2012, 02:33 AM
RE: New Project16B Cathedral - by AI2V - 06-21-2012, 09:32 AM
RE: New Project16B Cathedral - by TA Forbes - 06-21-2012, 12:36 PM
Philco 91 Tuning Condenser
There are currently 5946 online users. [Complete List]
» 2 Member(s) | 5944 Guest(s)
