Philco 37-361
(04-24-2012, 09:51 PM)cmhsr Wrote:  The wires are connected as you suggest. I cut them off at the bottom of the Electrolytic capacitor can. Both were connected to the same single pole coming out of the bottom of the can. The new capacitor has two leads, one on each end. Do I connect both wires to one end and ground the other or does each end get one of the wires?
Chuck
Got it connected. Thanks do I delete this thread until my next question .
Philco 37-161 - by cmhsr - 04-20-2012, 03:49 PM
RE: Philco 37-161 - by Ron Ramirez - 04-20-2012, 07:52 PM
RE: Philco 37-161 - by cmhsr - 04-20-2012, 07:54 PM
RE: Philco 37-161 - by Ron Ramirez - 04-20-2012, 07:56 PM
RE: Philco 37-361 - by Ron Ramirez - 04-23-2012, 08:35 PM
RE: Philco 37-361 - by cmhsr - 04-23-2012, 09:13 PM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 05:26 AM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 08:21 AM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 08:34 AM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 06:55 PM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 07:30 PM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 07:50 PM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 09:06 PM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 09:51 PM
RE: Philco 37-361 - by cmhsr - 04-25-2012, 09:31 PM
RE: Philco 37-361 - by cmhsr - 04-27-2012, 06:39 PM
RE: Philco 37-361 - by Ron Ramirez - 04-27-2012, 08:45 PM
RE: Philco 37-361 - by cmhsr - 04-28-2012, 09:03 AM
RE: Philco 37-361 - by cmhsr - 04-28-2012, 06:50 PM
RE: Philco 37-361 - by cmhsr - 04-29-2012, 12:28 PM
RE: Philco 37-361 - by Ron Ramirez - 04-29-2012, 02:06 PM
RE: Philco 37-361 - by cmhsr - 04-29-2012, 04:23 PM
RE: Philco 37-361 - by cmhsr - 04-29-2012, 04:29 PM
RE: Philco 37-361 - by cmhsr - 05-01-2012, 03:40 PM
RE: Philco 37-361 - by John R - 05-01-2012, 04:51 PM
RE: Philco 37-361 - by cmhsr - 05-01-2012, 06:58 PM
RE: Philco 37-361 - by cmhsr - 05-11-2012, 10:08 AM
RE: Philco 37-361 - by cmhsr - 05-11-2012, 10:40 AM
RE: Philco 37-361 - by cmhsr - 05-23-2012, 06:06 PM
Philco 37-361 - by cmhsr - 04-23-2012, 07:36 PM
The speaker table error?
Philco 70 antenna lead
