And this is a what?
So I payed to much for a 39-45 today ($100) Single mother 3 kids etc etc. But consoles are hard to find here in Vegas, and other than 1 tube shield base that was ripped out to put a GT tube in, it's all there.
But what caught my eye ( other than the young ladies chest Icon_redface ) was this thing screwed to the back of the cabinet. It has P/N 27-9184 cast into the back side and PHILCO ANT. GND and SET cast into the front. I'm assuming a lightning arrestor but don't know for sure. It's ceramic and potted like our favorite caps.
So what is it?
John
Las Vegas, NV USA
And this is a what? - by LASJayhawk - 04-27-2012, 08:24 PM
RE: And this is a what? - by Ron Ramirez - 04-27-2012, 08:41 PM
RE: And this is a what? - by TA Forbes - 04-27-2012, 09:12 PM
RE: And this is a what? - by LASJayhawk - 04-27-2012, 09:17 PM
RE: And this is a what? - by TA Forbes - 04-27-2012, 10:23 PM
Philco 91 Tuning Condenser
