My 39-45 bandswitch had been neutered
I don't know how the switch looks, but in many switches using spring-and-ball detention, those balls are usually the same as those in some ball bearings, so if this is it, then you could get a ball bearing, get balls from there, and get your switch all...ballsy again.
RE: My 39-45 bandswitch had been neutered - by morzh - 04-29-2012, 05:34 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6947 online users. [Complete List]
» 1 Member(s) | 6946 Guest(s)
