Model 60B late antenna coil question
Update: I found more resistors that were way out. Funny, some of them were over 20% under value. Anyway, I aligned the set by ear and it is performing much better. With a 3ft wire in my basement I can pick up the 4 or so strong stations in my area and the shortwave has popped to life.
*EDITED*
That means the information in in the quote from Ron is CORRECT
Model 60B late antenna coil question - by jth877 - 04-29-2012, 01:16 AM
RE: Model 60B late antenna coil question - by jth877 - 04-30-2012, 10:27 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6931 online users. [Complete List]
» 1 Member(s) | 6930 Guest(s)
