Philco 66 - Sweet Music at Last!!
R28 and R29 OK. G1 of 75 a little over -1v. Do not get a loud hum on vol. control. G1 of 6A7 -3.3v.
Osc. coil? How do I check this and what is the repair?
This is pushing my limits of current ability. Will continue with all the advice.
Thanks!
Joe
Philco 66 - Sweet Music at Last!! - by jph14 - 04-22-2012, 08:07 PM
RE: Philco 66 - by codefox1 - 04-23-2012, 12:21 PM
RE: Philco 66 - by jph14 - 04-23-2012, 02:06 PM
RE: Philco 66 - by 7estatdef - 04-23-2012, 10:14 PM
RE: Philco 66 - by jph14 - 04-24-2012, 06:38 AM
RE: Philco 66 -Nothing - by jph14 - 04-27-2012, 09:53 AM
RE: Philco 66 -Nothing - by TA Forbes - 04-27-2012, 11:31 AM
RE: Philco 66 -Nothing - by jph14 - 04-27-2012, 01:28 PM
RE: Philco 66 -Nothing - by morzh - 04-27-2012, 11:57 AM
RE: Philco 66 -Nothing - by 7estatdef - 04-27-2012, 04:36 PM
RE: Philco 66 -Nothing - by jph14 - 04-27-2012, 04:50 PM
RE: Philco 66 -Nothing - by 7estatdef - 04-28-2012, 07:11 AM
RE: Philco 66 -Nothing - by jph14 - 04-29-2012, 11:50 AM
RE: Philco 66 -Nothing - by rghines1 - 04-29-2012, 02:47 PM
RE: Philco 66 -Nothing - by jph14 - 04-30-2012, 04:04 PM
RE: Philco 66 -Nothing - by rghines1 - 04-30-2012, 04:56 PM
RE: Philco 66 -Nothing - by jph14 - 04-30-2012, 07:47 PM
RE: Philco 66 -Nothing - by rghines1 - 04-30-2012, 08:55 PM
RE: Philco 66 -Nothing - by 7estatdef - 04-29-2012, 02:36 PM
RE: Philco 66 -Nothing - by jph14 - 05-01-2012, 04:10 PM
RE: Philco 66 -Nothing - by morzh - 05-01-2012, 04:20 PM
RE: Philco 66 -Nothing - by jph14 - 05-01-2012, 04:24 PM
RE: Philco 66 -Nothing - by morzh - 05-01-2012, 05:01 PM
RE: Philco 66 -Nothing - by jph14 - 05-03-2012, 11:11 AM
RE: Philco 66 -Nothing - by morzh - 05-03-2012, 02:45 PM
RE: Philco 66 -Nothing - by jph14 - 05-03-2012, 02:57 PM
RE: Philco 66 -Nothing - by rghines1 - 05-04-2012, 08:37 PM
RE: Philco 66 -Nothing - by jph14 - 05-05-2012, 05:26 PM
RE: Philco 66 - suspect coil issues - by jph14 - 05-12-2012, 05:34 PM
RE: Philco 66 - Coil troubles? - by jph14 - 05-26-2012, 07:26 AM
RE: Philco 66 - Coil troubles? - by jph14 - 05-27-2012, 12:23 PM
RE: Philco 66 - Coil troubles? - by codefox1 - 05-27-2012, 02:04 PM
RE: Philco 66 - Coil troubles? - by jph14 - 05-27-2012, 02:38 PM
RE: Philco 66 - Coil troubles? - by morzh - 05-27-2012, 05:03 PM
RE: Philco 66 - Coil troubles? - by morzh - 05-27-2012, 07:27 PM
RE: Philco 66 - Coil troubles? - by jph14 - 05-27-2012, 07:27 PM
RE: Philco 66 - Coil troubles? - by jph14 - 05-27-2012, 08:48 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 05-28-2012, 08:40 AM
RE: Philco 66 - Coil troubles? - by jph14 - 05-31-2012, 05:38 PM
RE: Philco 66 - Coil troubles? - by morzh - 05-31-2012, 07:35 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 05-31-2012, 08:28 PM
RE: Philco 66 - Coil troubles? - by jph14 - 05-31-2012, 09:20 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 05-31-2012, 09:31 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-01-2012, 06:42 AM
RE: Philco 66 - Coil troubles? - by jph14 - 06-01-2012, 03:07 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-01-2012, 03:52 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-02-2012, 01:57 PM
RE: Philco 66 - Coil troubles? - by morzh - 06-02-2012, 03:59 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-02-2012, 04:24 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-02-2012, 05:16 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-02-2012, 07:20 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-02-2012, 08:11 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-02-2012, 09:18 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-02-2012, 09:31 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-02-2012, 10:01 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-06-2012, 09:58 AM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-06-2012, 06:45 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-06-2012, 08:37 PM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-07-2012, 07:32 AM
RE: Philco 66 - Coil troubles? - by jph14 - 06-07-2012, 09:04 AM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-07-2012, 09:20 PM
RE: Philco 66 - Coil troubles? - by jph14 - 06-08-2012, 08:21 AM
RE: Philco 66 - Coil troubles? - by 7estatdef - 06-09-2012, 08:25 PM
RE: Philco 66 - Sweet Music! Hold on - by jph14 - 06-11-2012, 03:55 PM
RE: Philco 66 - Sweet Music! Hold on - by jph14 - 06-12-2012, 06:21 AM
RE: Philco 66 - Sweet Music! Hold on - by jph14 - 06-12-2012, 01:58 PM
RE: Philco 66 - Sweet Music at Last!! - by jph14 - 06-17-2012, 10:12 AM
Users browsing this thread: 30 Guest(s)
The speaker table error?
Philco 70 antenna lead
