Model 60B late antenna coil question
My apologies you are correct! I was counting the ground lug as Lug 1. So I was looking between lugs 1 and 4. Now it makes sense. I wish I found a diagram like that when I started working on this thing. At least someone will find it if they search in the future. Maybe a new topic for the website? Problematic coils and their respective schematics?
Model 60B late antenna coil question - by jth877 - 04-29-2012, 01:16 AM
RE: Model 60B late antenna coil question - by jth877 - 04-30-2012, 09:53 PM
The speaker table error?
Philco 70 antenna lead
There are currently 3326 online users. [Complete List]
» 3 Member(s) | 3323 Guest(s)
