Philco 37-361
(05-01-2012, 04:51 PM)John R Wrote:
(05-01-2012, 03:40 PM)cmhsr Wrote:  Ron I suspect concerning Capacitor 44 being hot to the touch could it be that resistor 19 on the schematic is bad, letting to much current through?
Go ahead & check R19 but I really suspect that the three section candohm resistor R43 has an open which would throw the biasing off and not allow a return to ground for C44. John
John
I am new to this so I appreciate the help. On the Number 44 Electroyltic cap. it is the can type and had one connection at the bottom and three wires connected to it. The ground simply connected to the can by being inserted under the paper wrap at the bottom of the can. My new Cap is the Aerial type, two wires, do I connect the old three wires to one side of the new cap and what do I connect the neg side to the old ground with or do I leave it alone and connect the old ground wire to the chassis.
Philco 37-161 - by cmhsr - 04-20-2012, 03:49 PM
RE: Philco 37-161 - by Ron Ramirez - 04-20-2012, 07:52 PM
RE: Philco 37-161 - by cmhsr - 04-20-2012, 07:54 PM
RE: Philco 37-161 - by Ron Ramirez - 04-20-2012, 07:56 PM
RE: Philco 37-361 - by Ron Ramirez - 04-23-2012, 08:35 PM
RE: Philco 37-361 - by cmhsr - 04-23-2012, 09:13 PM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 05:26 AM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 08:21 AM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 08:34 AM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 06:55 PM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 07:30 PM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 07:50 PM
RE: Philco 37-361 - by Ron Ramirez - 04-24-2012, 09:06 PM
RE: Philco 37-361 - by cmhsr - 04-24-2012, 09:51 PM
RE: Philco 37-361 - by cmhsr - 04-25-2012, 09:31 PM
RE: Philco 37-361 - by cmhsr - 04-27-2012, 06:39 PM
RE: Philco 37-361 - by Ron Ramirez - 04-27-2012, 08:45 PM
RE: Philco 37-361 - by cmhsr - 04-28-2012, 09:03 AM
RE: Philco 37-361 - by cmhsr - 04-28-2012, 06:50 PM
RE: Philco 37-361 - by cmhsr - 04-29-2012, 12:28 PM
RE: Philco 37-361 - by Ron Ramirez - 04-29-2012, 02:06 PM
RE: Philco 37-361 - by cmhsr - 04-29-2012, 04:23 PM
RE: Philco 37-361 - by cmhsr - 04-29-2012, 04:29 PM
RE: Philco 37-361 - by cmhsr - 05-01-2012, 03:40 PM
RE: Philco 37-361 - by John R - 05-01-2012, 04:51 PM
RE: Philco 37-361 - by cmhsr - 05-01-2012, 06:58 PM
RE: Philco 37-361 - by cmhsr - 05-11-2012, 10:08 AM
RE: Philco 37-361 - by cmhsr - 05-11-2012, 10:40 AM
RE: Philco 37-361 - by cmhsr - 05-23-2012, 06:06 PM
Philco 37-361 - by cmhsr - 04-23-2012, 07:36 PM
The speaker table error?
Philco 70 antenna lead
