Philco 77 volume control
The wattage of the pot was my next question, so it should be at least 5w. Does it hurt to go bigger if I can find one @1750 ohms?
(05-01-2012, 06:33 PM)morzh Wrote:  Other manual shows 2K, but that beside the point.
This pot needs to dissipate quite a bit, huh.....3W dissipation will make it 5 to 7 W rated pot at least.
I was about to suggest trying to trick that thing: you can connect a large, say, 6-8W resistor of 2.1K in parallel to the ends of the pot (the circuit will see an equivalent of 1.72K) and try to regulate it this way, but I am not sure what the 10K pot's rated dissipation is - needs to dissipate 1/2 Watt, so needs to be 1-2W rated at least.
You can try.....
Philco 77 volume control - by kenlew0405 - 04-21-2012, 10:55 PM
RE: Philco 77 volume control - by murf - 04-21-2012, 11:14 PM
RE: Philco 77 volume control - by kenlew0405 - 04-22-2012, 12:04 AM
RE: Philco 77 volume control - by 7estatdef - 04-23-2012, 10:25 PM
RE: Philco 77 volume control - by 7estatdef - 04-29-2012, 07:50 PM
RE: Philco 77 volume control - by kenlew0405 - 05-01-2012, 02:32 PM
RE: Philco 77 volume control - by morzh - 05-01-2012, 04:05 PM
RE: Philco 77 volume control - by Ron Ramirez - 05-01-2012, 05:02 PM
RE: Philco 77 volume control - by morzh - 05-01-2012, 05:41 PM
RE: Philco 77 volume control - by kenlew0405 - 05-01-2012, 05:59 PM
RE: Philco 77 volume control - by morzh - 05-01-2012, 06:07 PM
RE: Philco 77 volume control - by kenlew0405 - 05-02-2012, 08:16 AM
RE: Philco 77 volume control - by morzh - 05-01-2012, 06:33 PM
RE: Philco 77 volume control - by kenlew0405 - 05-02-2012, 08:15 AM
RE: Philco 77 volume control - by 7estatdef - 05-01-2012, 08:19 PM
RE: Philco 77 volume control - by Ron Ramirez - 05-02-2012, 08:25 AM
RE: Philco 77 volume control - by morzh - 05-02-2012, 08:57 AM
RE: Philco 77 volume control - by Ron Ramirez - 05-02-2012, 09:04 AM
RE: Philco 77 volume control - by kenlew0405 - 05-02-2012, 04:05 PM
RE: Philco 77 volume control - by morzh - 05-02-2012, 04:45 PM
RE: Philco 77 volume control - by kenlew0405 - 05-16-2012, 03:51 PM
The speaker table error?
Philco 70 antenna lead
