  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
Believe me the last thing I want to do is change anything. I blast people out of the room with my 10S669 Zenith and it has it's original speaker so I will definitely retain the cone on the Philco if its in decent shape. It is composed of two different materials. Whats the significance of that design?
RE: Growing up quick...with a 38-690xx - by badwaxcaps - 05-02-2012, 07:05 PM
Users browsing this thread: 14 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6880 online users. [Complete List]
» 1 Member(s) | 6879 Guest(s)
