Opinions please on this Zenith console
Eliot,
Thanks for heads up. Once I finish my AA5 Zenith 6G001, (just restored a quad electrolytic cap) this is my next project. Can't wait. Never saw a motorized drive before.
RE: Opinions please on this Zenith console - by morzh - 05-03-2012, 09:23 AM
There are currently 10651 online users. [Complete List]
» 2 Member(s) | 10649 Guest(s)
