My First Philco
$5? Nice find. I'm still working on my first radio myself, so I don't completely know what I'm up against yet, but I'd think that you'll almost certainly come out ahead on the project--I'm sure there's at least $5 worth of entertainment in that alone! Congrats on finding one as complete as you did.
My First Philco - by Salval - 05-03-2012, 05:50 PM
RE: My First Philco - by DeckApe - 05-03-2012, 05:57 PM
RE: My First Philco - by Arran - 05-03-2012, 06:23 PM
RE: My First Philco - by codefox1 - 05-03-2012, 06:52 PM
RE: My First Philco - by LASJayhawk - 05-03-2012, 07:05 PM
RE: My First Philco - by Ron Ramirez - 05-03-2012, 07:14 PM
RE: My First Philco - by Arran - 05-04-2012, 06:34 PM
RE: My First Philco - by TA Forbes - 05-03-2012, 08:30 PM
RE: My First Philco - by Salval - 05-05-2012, 09:18 PM
RE: My First Philco - by TA Forbes - 05-05-2012, 10:14 PM
Philco 91 Tuning Condenser
There are currently 5970 online users. [Complete List]
» 2 Member(s) | 5968 Guest(s)
