Philco bakelite condenser 4989 Z?
Hi,
I just started a restoration of a model 60 cathedral and came across a bakelite condenser 4989 Z. According to the schematic I have it is a .18 single but upon removing the wax there are two caps inside. I was on philco repair bench and a Z version is not on there for a 4989. I have 0.22uf caps can I use these and what pin is the double? Just want to be sure.
thanks
Chris
Philco bakelite condenser 4989 Z? - by Philcofan - 05-06-2012, 03:33 PM
The speaker table error?
Philco 70 antenna lead
