Philco bakelite condenser 4989 Z?
Hi
The 4989-Z has two .09 uF caps in parallel to make .18 uF. You will note there is an external jumper wire between the center terminal and the outermost terminal; the grounded terminal is common to both caps.
Yes, you can use a single 0.22 uF in place of the two, or two single 0.1 uF caps. Close enough for gubmint work, as they say.
Philco bakelite condenser 4989 Z? - by Philcofan - 05-06-2012, 03:33 PM
RE: Philco bakelite condenser 4989 Z? - by Ron Ramirez - 05-06-2012, 05:34 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6655 online users. [Complete List]
» 1 Member(s) | 6654 Guest(s)
