CL leads me to a Philco 51 lowboy/Results
(05-06-2012, 01:23 PM)TA Forbes Wrote:  Better replace the electrolytics and wax/paper caps before you play it much more, as you may damage other components like your power transformer.
For sure! I just did the electrolytics and 2 of the bakelite blocks. I like to power up half way after each replacement, though, to make sure I haven't made it worse! I love when I do the one that makes a big difference.
RE: CL leads me to a Philco 51 lowboy - by Arran - 05-01-2012, 12:59 AM
RE: CL leads me to a Philco 51 lowboy/Results - by DKinYORKpa - 05-07-2012, 12:53 PM
Philco 91 Tuning Condenser
There are currently 5367 online users. [Complete List]
» 1 Member(s) | 5366 Guest(s)
