Some Russian guy restoring a console - worth taking a look
(05-04-2012, 09:25 PM)morzh Wrote:  Better yet, they did the blind test with an el cheapo CD player behind a curtain, telling an audiophile auditory that they were switching between a regular and hi-end tube amplifiers.
The hi-end consistently won. Only for the curtain to be lifted at the end and the Hi-Fi equipment (the el cheapo CD) revealed, together with admitting it was playing all the time.
I think them audiophiles were pissed.
Audiophools aside, I see some great craftmanship far beyond my abilities. Text translation not necessary.
Wonder what they had to pay to get everything re-chromed?
There are currently 10144 online users. [Complete List]
» 3 Member(s) | 10141 Guest(s)
