volume Philco 38-116
Murf my 37-116 cranked up will set the neighbors car alarm off 2 doors down.
Does the volume go way down with the treble control fully counterclockwise? that would be a good indication the IF is way out of alignment.
John
Las Vegas, NV USA
volume Philco 38-116 - by murf - 05-07-2012, 10:18 PM
RE: volume Philco 38-116 - by Chuck Schwark - 05-07-2012, 10:29 PM
RE: volume Philco 38-116 - by murf - 05-07-2012, 10:44 PM
RE: volume Philco 38-116 - by LASJayhawk - 05-08-2012, 12:31 AM
RE: volume Philco 38-116 - by murf - 05-08-2012, 06:52 AM
RE: volume Philco 38-116 - by TA Forbes - 05-08-2012, 10:06 AM
RE: volume Philco 38-116 - by morzh - 05-08-2012, 10:16 AM
RE: volume Philco 38-116 - by codefox1 - 05-08-2012, 10:34 AM
RE: volume Philco 38-116 - by morzh - 05-08-2012, 01:52 PM
RE: volume Philco 38-116 - by murf - 05-08-2012, 04:16 PM
RE: volume Philco 38-116 - by murf - 05-08-2012, 04:32 PM
RE: volume Philco 38-116 - by morzh - 05-08-2012, 04:48 PM
RE: volume Philco 38-116 - by morzh - 05-09-2012, 03:00 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7098 online users. [Complete List]
» 2 Member(s) | 7096 Guest(s)
