I need transfer letter philco and dial philco
hello I need, transferable letters of the philco, i have one radio Philco 60, but it have not the letter
And i need some dial, original o reproduction og dial philco.
where I can find this pieces letter and dial ?
thank you, Mauricio
I need transfer letter philco and dial philco - by Mauricio - 01-08-2007, 03:55 PM
[No subject] - by Chuck Schwark - 01-08-2007, 04:49 PM
Philco 91 Tuning Condenser
There are currently 9931 online users. [Complete List]
» 1 Member(s) | 9930 Guest(s)
