  • 1 Vote(s) - 4 Average
Ron's Cabinet Work for the 2012 Season
Agreed. I would rather try to follow the contour of the missing piece rather than cut an obvious square patch.
Well, today, I stripped another cabinet - this time, a 19B cathedral. As I usually do when I get in too much of a hurry, I forgot to take a "before" photo. Suffice it to say that the 19B is basically solid, and only has a couple minor veneer issues in front along with a very small piece of bottom trim missing on the right front. The old finish was very dull, very dirty, and very rough. Cleaning did not help - it (unfortunately) had to be stripped.
I'll post a photo of how the 19B looks now, later on.
RE: Ron's Cabinet Work for the 2012 Season - by Ron Ramirez - 05-12-2012, 04:26 PM
Users browsing this thread: 23 Guest(s)
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2544 online users. [Complete List]
» 3 Member(s) | 2541 Guest(s)
