A quad electrolytic re-stuffing
This is for restuffing quad electrolytic from Zenit 6G001Y, 2x40uF 200V, 20uF 200V and 200uF 10V.
First, the cap is taken out.
Then the flare is lifted.
The ground ring is taken out.
Then the cap is heated and the innyrds are extracted.
A quad electrolytic re-stuffing - by morzh - 05-12-2012, 05:47 PM
RE: A quad electrolytic re-stuffing - by morzh - 05-12-2012, 05:54 PM
There are currently 8644 online users. [Complete List]
» 1 Member(s) | 8643 Guest(s)
