Need help with a Philco Console I got at a Garage sale
I just picked up a Philco console stereo at a garage sale for $15
It works just fine and just needs some refinishing.
Only problem is it doesn't have a needle in the record player and I don't know which one I need for a replacement.
I have attached some pictures of the end of the record player arm along with the record player(still has the packaging on it) and a picture of the total radio.
Does anyone know what needle this takes and where I could find some to buy online?
Thanks for your help
Need help with a Philco Console I got at a Garage sale - by dart31 - 05-12-2012, 07:06 PM
Philco 91 Tuning Condenser
