Philco 46-200 122 SW Band?
Hi everybody,
Finally got my little Philco 46-200 122 working, but for the life of me, I can't figure out how the SW band works. The dial is marked Broadcast and 200 to 500 meters, but no band-switch.
Using the Breitman Schematic.
I hesitated to ask because it's probably obvious. Just not to me.
lyle
I may not be very good, but I'm slow.
Philco 46-200 122 SW Band? - by lyle - 05-14-2012, 05:46 PM
RE: Philco 46-200 122 SW Band? - by 7estatdef - 05-14-2012, 05:59 PM
RE: Philco 46-200 122 SW Band? - by lyle - 05-14-2012, 07:53 PM
The speaker table error?
Philco 70 antenna lead
