Philco 46-200 122 SW Band?
Huh the 200-500 meters is the AM band measured in wavelength rather than frequency. This set has no SW band.
Philco 46-200 122 SW Band? - by lyle - 05-14-2012, 05:46 PM
RE: Philco 46-200 122 SW Band? - by 7estatdef - 05-14-2012, 05:59 PM
RE: Philco 46-200 122 SW Band? - by lyle - 05-14-2012, 07:53 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7454 online users. [Complete List]
» 3 Member(s) | 7451 Guest(s)
