37-610 semi fixed condensors
Codefox nailed it. They have the appearance and construction of trimmer condensers (capacitors), but they are not meant to be adjusted. They were adjusted to a certain value in pF at the factory and were meant to be left alone from then on.
37-610 semi fixed condensors - by Philcofan - 05-13-2012, 06:52 PM
RE: 37-610 semi fixed condensors - by TA Forbes - 05-13-2012, 06:56 PM
RE: 37-610 semi fixed condensors - by Philcofan - 05-13-2012, 07:00 PM
RE: 37-610 semi fixed condensors - by morzh - 05-13-2012, 08:03 PM
RE: 37-610 semi fixed condensors - by codefox1 - 05-14-2012, 12:45 PM
RE: 37-610 semi fixed condensors - by 7estatdef - 05-14-2012, 06:06 PM
RE: 37-610 semi fixed condensors - by Ron Ramirez - 05-14-2012, 08:13 PM
RE: 37-610 semi fixed condensors - by Philcofan - 05-17-2012, 07:07 PM
The speaker table error?
Philco 70 antenna lead
