Model 39-70 major parts malfunction
The 39-70 looks to be a typical farm radio from the late 30's.
Farm radios refer to the units built that ran on batteries, and were designed for rural areas prior to electrification.
If you're interested in what the schematic for it looks like, here's a link.
http://www.nostalgiaair.org/PagesByModel...013302.pdf
Good luck in your search!
Bill
Sent from my Pentium II on the AT&T Dial Network
Model 39-70 major parts malfunction - by Guest - 01-15-2007, 04:01 PM
[No subject] - by Chuck Schwark - 01-15-2007, 04:40 PM
[No subject] - by Guest - 01-20-2007, 06:53 AM
[No subject] - by Bill Hutchinson - 01-20-2007, 08:42 PM
There are currently 9197 online users. [Complete List]
» 3 Member(s) | 9194 Guest(s)
