Transitone PT-6
Welcome to the Phorum.
Your 1941 Philco Transitone set is a nice table model with classic looks.
More comprehensive service info can be obtained thru my website as well.
My archive of all original Philco bulletins has info Riders, many times left out.
Many good guys here who can help you with your set.
Chuck
Transitone PT-6 - by unit91 - 05-15-2012, 11:09 AM
RE: Transitone PT-6 - by tab10672 - 05-15-2012, 03:21 PM
RE: Transitone PT-6 - by tab10672 - 05-15-2012, 03:23 PM
RE: Transitone PT-6 - by unit91 - 05-15-2012, 04:25 PM
RE: Transitone PT-6 - by Chuck Schwark - 05-15-2012, 07:31 PM
RE: Transitone PT-6 - by unit91 - 05-16-2012, 09:54 AM
RE: Transitone PT-6 - by markskala - 05-23-2012, 04:28 PM
Philco 91 Tuning Condenser
There are currently 3018 online users. [Complete List]
» 1 Member(s) | 3017 Guest(s)
