Saved from the trash.
It's an FM set I believe, but other then that one button it looks like it's all there. The unfortunate thing about it is that the poor condition of the faux finish on the cabinet, it would be interesting to replace that faux dinoc wood grain with real veneer, the design isn't too bad for a post war console.
Saved from the trash. - by Jayce - 05-15-2012, 11:03 PM
RE: Saved from the trash. - by Arran - 05-16-2012, 02:16 AM
RE: Saved from the trash. - by Jayce - 05-16-2012, 11:18 AM
RE: Saved from the trash. - by Arran - 05-17-2012, 10:52 PM
RE: Saved from the trash. - by Jayce - 05-18-2012, 08:03 PM
Philco 91 Tuning Condenser
