Saved from the trash.
Yeah, that's the issue with the postwar Zeniths for sure. They went wild with the dinoc finish! These things look nice with the finish intact, but are a pain when it degrades. I guess they made a chippendale version of this too with the tuner and phonograph side by side. I know someone who has two or three of those just collecting dust in storage. I couldn't beat the price of this one though. Icon_smile
Saved from the trash. - by Jayce - 05-15-2012, 11:03 PM
RE: Saved from the trash. - by Arran - 05-16-2012, 02:16 AM
RE: Saved from the trash. - by Jayce - 05-16-2012, 11:18 AM
RE: Saved from the trash. - by Arran - 05-17-2012, 10:52 PM
RE: Saved from the trash. - by Jayce - 05-18-2012, 08:03 PM
There are currently 8236 online users. [Complete List]
» 2 Member(s) | 8234 Guest(s)
