37-690 Power Supply Chassis Rebuild
Thirtiesradio,
Thanks for the "thumbs up!"
I took my bakelite blocks all the way out.
Are you going to install a the original 1uf NP bypass cap or install the suggested 4.7uf or 10uf cap for the tweeters?
camman
37-690 Power Supply Chassis Rebuild - by camman - 05-10-2012, 10:31 AM
RE: 37-690 Power Supply Chassis Rebuild - by camman - 05-17-2012, 05:12 PM
The speaker table error?
Philco 70 antenna lead
