Ron's Cabinet Work for the 2012 Season
Codefox - I have not yet taken photos of the decals, but I will be doing so in the coming weeks. As soon as I do, I'll send them to you. Thanks!
Meantime, folks, here's the photo of how my 19B looks now.
[Image: http://www.philcoradio.com/images/phorum..._00005.jpg]
It would be a lot easier to refinish if I could get the front panel out of the cabinet. Philco not only used several wood screws to hold the panel in, they also glued the panel into place.
RE: Ron's Cabinet Work for the 2012 Season - by Ron Ramirez - 05-17-2012, 07:05 PM
Users browsing this thread: 13 Guest(s)
With these values I think you are OK; the Cmax for this tube is 40uF.
Your Vbb could rise a bit, but probably not too mu...morzh — 04:53 PM |
BTW, someone had replaced the original 20uF/20uF filter cap with a 47uF/33uF cap. Do you think these values are safe on ...bluecap — 04:33 PM |
You're correct. I was misinterpreting the key position. I now know where it is, and things are making sense. I appreciat...bluecap — 04:29 PM |
I think Morzh has a good thought. Check the key position. The under chassis diagram in the Philco info shows an “H” for ...klondike98 — 04:25 PM |
Philco 630csx power cord
Yes, the third wire goes to the stud on the side and is separate from the other two.
I've usually used cloth covered ...Tynwald — 03:09 PM |
New member
Have you tried Alabama Historical Radio Society?
They possibly could recommend someone.
I remember a name of Dee Hanes...morzh — 03:08 PM |
Nope, he can’t tell me the dimensions. Looks like I won’t be buying it.jrblasde — 02:38 PM |
Hello Joseph ,
It sounds like you found a good seller and yes shipping is really expensive !
Sincerely Richardradiorich — 02:16 PM |
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM |
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM |
There are currently 2047 online users. [Complete List] » 3 Member(s) | 2044 Guest(s)
