Saved from the trash.
In looking at the pictures, does the top use real veneer but the front uses the dinoc finish? Even though it is a radio/phono combo unit I sort of like the design.
Saved from the trash. - by Jayce - 05-15-2012, 11:03 PM
RE: Saved from the trash. - by Arran - 05-16-2012, 02:16 AM
RE: Saved from the trash. - by Jayce - 05-16-2012, 11:18 AM
RE: Saved from the trash. - by Arran - 05-17-2012, 10:52 PM
RE: Saved from the trash. - by Jayce - 05-18-2012, 08:03 PM
There are currently 5740 online users. [Complete List]
» 2 Member(s) | 5738 Guest(s)
