Newest acquisition - a 37-670B
Cats often "supervise" what you are doing. If they approve of it, they rub on whatever it is you are paying attention to. If they do not approve, they sit on whatever you are doing so that you must stop.
My 37-670 does not have the export power transformer. My 38-650 does have it.
Newest acquisition - a 37-670B - by Ron Ramirez - 05-17-2012, 07:11 PM
RE: Newest acquisition - a 37-670B - by Arran - 05-18-2012, 08:31 PM
RE: Newest acquisition - a 37-670B - by TA Forbes - 05-19-2012, 10:03 AM
RE: Newest acquisition - a 37-670B - by codefox1 - 05-19-2012, 05:32 PM
RE: Newest acquisition - a 37-670B - by TA Forbes - 05-19-2012, 09:15 PM
Philco 91 Tuning Condenser
