Found inside a homebrew
Along with 2 other books was this 1934 Philco radio log. Even has a listing in for listening to Admiral Byrds 2nd Antarctic expedition.
[Image: http://i248.photobucket.com/albums/gg187...w001-1.jpg]
Found inside a homebrew - by Jim Dutridge - 05-19-2012, 03:10 PM
RE: Found inside a homebrew - by fixinmyphilco - 05-19-2012, 06:59 PM
RE: Found inside a homebrew - by TA Forbes - 05-20-2012, 12:29 PM
Philco 91 Tuning Condenser
