New Philco 51 question/ANSWERED
On my Riders, for the alignment it says to refer to the "illustration above for the location of the various compensating condensers." There is no illustration above. The parts layout does assign a numbers to the comp. conds., but I can only find them on the schematic, which isn't enough for me. I would also need to know which trimmer is which on top of the tuning cap. Any help out there?
New Philco 51 question/ANSWERED - by DKinYORKpa - 05-19-2012, 04:18 PM
RE: New Philco 51 question - by tab10672 - 05-19-2012, 05:00 PM
RE: New Philco 51 question - by tab10672 - 05-19-2012, 05:07 PM
Philco 91 Tuning Condenser
