Model 16 Volume Control
Mark Oppat of OLD RADIO PARTS can help you with a replacement.
See his link on my RESOURCE LINKS page - scroll down about 3-4 vendors.
Model 16 Volume Control - by Guest - 01-24-2007, 11:50 AM
[No subject] - by Chuck Schwark - 01-24-2007, 01:26 PM
There are currently 8874 online users. [Complete List]
» 3 Member(s) | 8871 Guest(s)
