Zenith 6s321 transformer help
i have not applied any voltage to the transformer. I'm checking my meters making sure they are ok.
I will check from the center tap to the windings. There was a wax like material all over the bottom of the transformer. About 3/16 thick.
I used the diagram with the tubes on it and a tube book to put the info on the schematics.
Zenith 6s321 transformer help - by Bradley Rush - 05-19-2012, 11:15 AM
RE: Zenith 6s321 transformer help - by morzh - 05-19-2012, 04:53 PM
RE: Zenith 6s321 transformer help - by Arran - 05-19-2012, 08:16 PM
RE: Zenith 6s321 transformer help - by morzh - 05-19-2012, 08:40 PM
RE: Zenith 6s321 transformer help - by Bradley Rush - 05-20-2012, 06:55 AM
RE: Zenith 6s321 transformer help - by morzh - 05-20-2012, 03:04 PM
Philco 91 Tuning Condenser
There are currently 10443 online users. [Complete List]
» 2 Member(s) | 10441 Guest(s)
