4-Band dial scale #27-5039---What Model #?
My 16B Cathedral has a 1935 four-band, dual drive chassis that I installed in it. I used a K-17 speaker with plug.
http://s1194.photobucket.com/albums/aa37...20chassis/
RE: 4-Band dial scale #27-5039---What Model #? - by TA Forbes - 05-20-2012, 12:27 PM
Philco 91 Tuning Condenser
There are currently 4381 online users. [Complete List]
» 1 Member(s) | 4380 Guest(s)
