Lost that
http://www.ebay.com/itm/200758996565?ssP...5062wt_948
This Clpper Bomber was owned by an actual bombardier. 610 proved too much (500 for these in a good shape is not unusual).
Lost that - by morzh - 05-20-2012, 09:42 PM
Eico 232 VTVM Schematic
There are currently 5903 online users. [Complete List]
» 2 Member(s) | 5901 Guest(s)
