Another 48-482
Agree, the electrolytics are time bombs and can do a lot of damage when they go. Also the coupling and bypass capacitors - no way they aren't leaking.
Another 48-482 - by LASJayhawk - 05-20-2012, 06:46 PM
RE: Another 48-482 - by Arran - 05-20-2012, 09:00 PM
RE: Another 48-482 - by LASJayhawk - 05-20-2012, 09:40 PM
RE: Another 48-482 - by codefox1 - 05-21-2012, 12:35 PM
Philco 91 Tuning Condenser
