Found a 625 today
Darn good shape! Ya dunn real good.
A rather hard model to come across too.
Icon_thumbup
Chuck
Found a 625 today - by Jim Dutridge - 05-18-2012, 07:34 PM
RE: Found a 625 today - by Ron Ramirez - 05-18-2012, 09:30 PM
RE: Found a 625 today - by Chuck Schwark - 05-21-2012, 10:25 PM
RE: Found a 625 today - by Arran - 05-21-2012, 11:22 PM
RE: Found a 625 today - by 7estatdef - 05-22-2012, 06:57 AM
RE: Found a 625 today - by Chuck Schwark - 05-22-2012, 09:49 AM
RE: Found a 625 today - by Ron Ramirez - 05-22-2012, 06:18 PM
Philco 91 Tuning Condenser
