Does Model 89 Require Shield On 75 Tube?
yes it is/was, Also where is the owner grounded? if he uses earth/neutral from his outlet that will sometimes cause the same problem.
RE: Does Model 89 Require Shield On 75 Tube? - by tab10672 - 05-23-2012, 12:56 AM
The speaker table error?
Philco 70 antenna lead
