What is the correct resisior wattage
I'm working on a 41-285F that is coming along nicely. I'm about to replace the out of spec resistors and would like to know what wattage rating I should use. For example, there is one 10M ohm resistor that passes less than a volt, would a 1/4 watt rating be too small or should I go higher? The original is pretty small in size.
Rick
What is the correct resisior wattage - by Guest - 02-08-2007, 12:38 PM
[No subject] - by Chuck Schwark - 02-08-2007, 01:09 PM
[No subject] - by Guest - 02-08-2007, 04:33 PM
There are currently 6921 online users. [Complete List]
» 2 Member(s) | 6919 Guest(s)
