GILFILLAN 66AM 66DM
There is no L8 in this document.
There is L5 which is 1500 Ohm.
It is the field coil of your speaker.
If it reads 500K, you should re-wind it.
If it is not the field coil, look at the sch again and make sure you show the correct reference designator before we go and search at it again.
L8 is not in the parts list either.
GILFILLAN 66AM 66DM - by Bradley Rush - 05-24-2012, 03:05 AM
RE: GILFILLAN 66AM 66DM - by morzh - 05-24-2012, 09:26 AM
RE: GILFILLAN 66AM 66DM - by Arran - 05-24-2012, 09:03 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-28-2012, 03:52 PM
RE: GILFILLAN 66AM 66DM - by morzh - 05-28-2012, 07:55 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-29-2012, 01:29 AM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-31-2012, 02:03 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 06-03-2012, 05:24 AM
RE: GILFILLAN 66AM 66DM - by morzh - 06-03-2012, 11:07 AM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 06-03-2012, 11:07 PM
There are currently 5727 online users. [Complete List]
» 2 Member(s) | 5725 Guest(s)
