philco 48-214 code 125 Cap ?
Open filament is easy to check. If your bulb is blown, ot you remove it, does the radio keep playing and the rectifier glowing? If yes, that will exclude the open filament.
The initial statement says "The radio plays great".
philco 48-214 code 125 Cap ? - by Eric - 05-20-2012, 01:18 PM
RE: philco 48-214 code 125 Cap ? - by codefox1 - 05-20-2012, 02:17 PM
RE: philco 48-214 code 125 Cap ? - by Eric - 05-20-2012, 03:10 PM
RE: philco 48-214 code 125 Cap ? - by Arran - 05-20-2012, 09:18 PM
RE: philco 48-214 code 125 Cap ? - by morzh - 05-23-2012, 08:37 PM
RE: philco 48-214 code 125 Cap ? - by 7estatdef - 05-23-2012, 09:07 PM
RE: philco 48-214 code 125 Cap ? - by morzh - 05-23-2012, 09:10 PM
RE: philco 48-214 code 125 Cap ? - by Arran - 05-23-2012, 11:25 PM
RE: philco 48-214 code 125 Cap ? - by morzh - 05-24-2012, 09:28 AM
RE: philco 48-214 code 125 Cap ? - by Eric - 05-24-2012, 03:14 PM
RE: philco 48-214 code 125 Cap ? - by codefox1 - 05-24-2012, 10:13 PM
RE: philco 48-214 code 125 Cap ? - by Eric - 05-29-2012, 03:08 PM
RE: philco 48-214 code 125 Cap ? - by 7estatdef - 05-30-2012, 07:15 AM
RE: philco 48-214 code 125 Cap ? - by morzh - 05-30-2012, 08:25 PM
The speaker table error?
Philco 70 antenna lead
