Philco 66 - Sweet Music at Last!!
City: Sedona, AZ/Placentia/CA
Joe, really need to get the audio amp section working well before chasing signals from the antenna or injection of signals from your generator. Particularly if your working without a scope. If your using the speaker output to do things and the amp is not working properly, well, it's like working in the dark. Tone insertion on the control grid of the output tube and the first audio seem to be the next phase as was indicated earlier. You will be after the volume control so keep the generator audio gain down low. Hate to see you put a large signal in and launch your speaker cone. Needless to say, you also need to confirm the voltages on the two tubes. Something is wrong in the audio if your not getting a hum out while touching the center tap of the volume control with the volume up. Voltage measurements will give you good idea where the problem is. Signal input to the two control grids will also tell you which section. It could be something as simple as the wires going to the speaker are not wired correctly. They are color coded on the schematic. I only suggest that as you indicated in a previous post that they were disconnected.
Good luck and we are watching. The audio section is pretty straight forward.
Jerry
RE: Philco 66 - Coil troubles? - by jerryhawthorne - 05-26-2012, 04:15 PM
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
