118H shadowmeter resistance
Should be about 1.1K.
118H shadowmeter resistance - by Glenn Roberts - 05-27-2012, 07:41 PM
RE: 118H shadowmeter resistance - by 7estatdef - 05-28-2012, 08:55 AM
RE: 118H shadowmeter resistance - by morzh - 05-28-2012, 02:00 PM
RE: 118H shadowmeter resistance - by 7estatdef - 05-28-2012, 04:13 PM
RE: 118H shadowmeter resistance - by 7estatdef - 06-01-2012, 05:18 PM
The speaker table error?
Philco 70 antenna lead
