GILFILLAN 66AM 66DM
http://www.flickr.com/photos/trog8/72891...hotostream
pic of the coil being used number name on it is as follows:
control corp
7c210
the item read 465K ohms
once removed the voltage at pin 8 6X5 went to 422vdc
I have checked and replaced both c18 B & C
All tubes check good none are weak
I will post schematics show show notes how in certain ver have this coil dis-attached from the speaker.
Its location was next to the power transformer on the bottom.
GILFILLAN 66AM 66DM - by Bradley Rush - 05-24-2012, 03:05 AM
RE: GILFILLAN 66AM 66DM - by morzh - 05-24-2012, 09:26 AM
RE: GILFILLAN 66AM 66DM - by Arran - 05-24-2012, 09:03 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-28-2012, 03:52 PM
RE: GILFILLAN 66AM 66DM - by morzh - 05-28-2012, 07:55 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-29-2012, 01:29 AM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 05-31-2012, 02:03 PM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 06-03-2012, 05:24 AM
RE: GILFILLAN 66AM 66DM - by morzh - 06-03-2012, 11:07 AM
RE: GILFILLAN 66AM 66DM - by Bradley Rush - 06-03-2012, 11:07 PM
Philco 91 Tuning Condenser
There are currently 10176 online users. [Complete List]
» 2 Member(s) | 10174 Guest(s)
